02-26-2015 10:14 AM
Hi everybody. I'm new on Labview. I want to create a VI which is show me Test Results. Anybody help me for this situation?
02-26-2015 10:19 AM
Taking the online tutorials are always a good way to learn LabVIEW.
How else did you expect to rectify this situation without studying how to program in LabVIEW?
02-26-2015 10:22 AM
I think it must be basic VI. It's only show test result pass or fail like a lamp.
02-26-2015 11:08 AM
Sounds like the the 1 Button Dialog would work for you. You just need to build up the string that gets displayed.
02-26-2015 01:42 PM
Ergin,
Are you trying to create a LabVIEW VI to use as a TestStand GUI? If this is the case I would probably post in the TestStand forums because custom UIs can a bit complicated even for simple tasks. You can take a look at the simple example located in \TestStand 2014\UserInterfaces\Simple\LabVIEW to get an idea of what is involved.
If you are just looking for an indication over whether the device passed or not, there may be other ways to do this, but again the TestStand forum would be able to guide you better on this.
If I misunderstood, and you are not using TestStand please explain what you are doing exactly and what your end goal is.
02-27-2015 03:16 AM
Thanks for your help. For example when Test Stand execution finished, if test result passed it show me dialog "Test Sequence Passed". I want to change it. I want to show another dialog. It show me uut number and test result. Can ı explain it?
02-27-2015 07:21 AM
02-28-2015 01:57 PM
Thanks. I'm looking it
