04-24-2007 10:10 PM - edited 04-24-2007 10:10 PM
I have LV 8.2. I can create a property node for caption visible and for label visible.
@johnsold wrote:
Be aware that you need to manually make the caption visible at edit time. If you have never done this for a particular control, the Caption.text property node returns error 1320. If there is a way to programmatically make the caption visible, I have not been able to find it.
Lynn
Message Edited by Ravens Fan on 04-24-2007 11:11 PM
04-25-2007 08:56 AM
04-25-2007 01:01 PM
04-25-2007 01:37 PM
04-25-2007 01:46 PM
"Is the compiler smart enough to not do anything with a property which is not connected?"
Yes! Same applies to functions that return a value but are un-wired.
Gotta watch that when doing bench-marks.
There maybe an exeption to the caption behaviour when it is wired to the icon connector since the labels shown when flaoting are really the captions.
The errors mentioned above are "by design" as of LV 7.0 (?).
Ben
