create OPC tag list for Eurotherm 2704
I am trying to convert an OPC export CSV for a  Eurotherm 2704 (using iTools OPC) into an NI OPC Import CSV, and although they are similar, the syntax for the the fields is quite different.  If I new the formats the NI OPC was expecting, I might be able to convert in a text editor, but I can't find any definitions online.  It seems to me that all 2704's have identical OPC tag lists, if I can do it once, then anyone using a 2704 should be able to use it.  Is there any sort of conversion tool between OPC server formats?
I have attached a small portion of an iTools OPC export CSV.
(2,357 Views)
Hello Craig,
Take a look at the following article. It discusses the appropriate format for the CSV to be used as an Import CSV.
CSV File Import and Export:
http://www.kepware.com/Products/feature-csvimportexport.asp
Ryan
Ryan P.
CLA
(2,285 Views)
