NI Home
Cart Cart | Help
You are here:
Reply
Member
o__o
Accepted Solution
crash when use indexe array with in place element structure
Hello !
I have a problem with in place element structure. I want index a waveform array (16 elements) and when i execute or save that labview close.... :smileyfrustrated:
I dont have problem with waveform array 15 elements or less, but i need index 16 elements... :smileysad:
Thanks for your help !!!:smileywink:
Member
o__o
Re : crash when use indexe array with in place element structure
I work with LV 8.5.1
Active Participant
ouadji
upload your code, thank you.
Member
o__o
I give you my code but it work because i used a waveform array with only 15 elements. I can't save or execute with 16 elements...
So add it (like picture Test.png) and you will see.
Thank you:smileyhappy:
Active Participant
pallen
I don't have that version of LV installed.  But I can tell you that LV 2011 does not crash when I added more elements to your posted code.
Patrick Allen
Member
o__o
thank you...
Active Participant
P@Anand
Even 2009 didn't crash after adding upto 20 indexes. So it may be an issue with 8.5 Version
I don't believe in Hard work. I love my work :smileyhappy:
Member
o__o
OK thanks
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
