crash when use indexe array with in place element structure
Hello !
I have a problem with in place element structure. I want index a waveform array (16 elements) and when i execute or save that labview close.... Smiley Frustrated
I dont have problem with waveform array 15 elements or less, but i need index 16 elements... 😞
Thanks for your help !!!Smiley Wink
Message 1 of 8
(2,439 Views)
I work with LV 8.5.1
Message 2 of 8
(2,437 Views)
upload your code, thank you.
Message 3 of 8
(2,426 Views)
I give you my code but it work because i used a waveform array with only 15 elements. I can't save or execute with 16 elements...
So add it (like picture Test.png) and you will see.
Thank youSmiley Happy
Message 4 of 8
(2,421 Views)
I don't have that version of LV installed.  But I can tell you that LV 2011 does not crash when I added more elements to your posted code.
Patrick Allen: FunctionalityUnlimited.ca
Message 5 of 8
(2,399 Views)
thank you...
Message 6 of 8
(2,388 Views)
Accepted by o__o
Even 2009 didn't crash after adding upto 20 indexes. So it may be an issue with 8.5 Version
Message 7 of 8
(2,385 Views)
OK thanks
Message 8 of 8
(2,364 Views)
