04-09-2015 01:34 AM
Good Day
I got an error when running VI( picoscope 5000EaxampleBlock vi) by using LabVIEW2014( LabVIEW crash ) This also been done by using a PIcoscope 5000 series meter
Exception: Access violation (0xC0000005) at EIP=0x0000000100000000
version: 14.0 (64-bit)
attached also Lv log and SubVI.
Can anybody advice on this matter..
Best Regard
AhmadTarmimi
Universiti Teknologi Malaysia
Solved! Go to Solution.
04-09-2015 07:44 AM
Without seeing the your scope drivers, this is just speculation...
Any time I have seen a crash like that from drivers it has been a call to a DLL that caused the problem. It may be that you are running 64 bit LV trying to call a 32 bit driver DLL.
04-09-2015 05:30 PM
Hi Bowen
Thank for the reply
the DLL file already use a 64 bit( download from picoscope website) but the VI i think in 32 bit version...
is there any method that chage VI from 32 bit version to 64 bit...
Best regards
Tarmimi
04-27-2015 09:48 AM
You install LV2014 x64.
/Y
04-27-2015 11:15 AM
/Y
Yes, then if you need to have a 32-bit version, have a dev statsion with LV 32-bit and the 32-bit dll. The VIs are just the source code and will open up just fine in either LV version.
The only issue is that LV 64-bit might not have the tool kits that you need.
