09-28-2015 08:30 AM
Hi everyone,I have multicolumn listbox and i have removed all lines both vertical and horizontal as well column and row headers.when i run my vi,some string data is fed into the listbox.However when i attempt to copy a line of string from the list box,i'm unable to do it(i am unable to select a line,..the idea is to select a line from this list box so i can paste it somewhere else..it's like am supposed to enable some feature of the list box in order to be able to do this..any help?thank already
Solved! Go to Solution.
09-28-2015 08:33 AM
Please post your VI
09-28-2015 08:50 AM
I have had to get the listbox from the original vi and create another one since the original vi requires certain electronic components for it to run successfully..!!..here it is
09-30-2015 04:09 AM
if I understood your problem, you would like to copy time and description values in one time and paste the entire line into a txt for example, right? Unfortunately the listbox is like a 2D string array and each field is a different value of this 2D array. You can copy one value at time when the VI is not RUN otherwise you can use a property node to show the Items Name and than copy and paste the values ( always one value at time ) also when the VI is RUN.
I hope that the information is helpful for your application
Regards
Mario
09-30-2015 04:27 AM
so this means that basically what i wanted to do is not possible at the moment,may be in the future..Thank you very much!!
