copy and paste VI blocks from one VI to another VI becomes a picture/image, why?
i am trying to copy and paste VI blocks from one VI program to another. but when i paste them, they become pictures/image format.... i can't connect any lines to any terminals on the pasted Vi blocks.... what is happening please??
i look forward to hear from you. thank you for your kind attention.
tmnt007
LabVIEW 8.2, WinXP
Message 1 of 9
(4,248 Views)
Could it be you're trying to copy from one LV version to another??
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 2 of 9
(4,241 Views)
Could you list the exact steps you go through to produce the problem?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 9
(4,211 Views)
A second guess could be if you're trying to copy code which is not supported in your version of LV (for example the Event structure in basic version).  I know that editing is allowed, but not creation.
Perhaps this is your problem?
Which LV version (number - 8.2, 7.1... and licence - basic, full, professional...) do you have?
Shane.
Message 4 of 9
(4,200 Views)
Hi shoneill and mikeporter,
thank you both for your concerns and enquiries...
For some reason, i can't reproduce the error i had, and now i can copy and paste the VIs as usual......
maybe the restart on LabVIEW helped...
Take care.
Message 5 of 9
(4,165 Views)
I think I saw something simlar when I was debugging an executable and tried to paste the code into the development environment.
Ben
Message 6 of 9
(4,147 Views)
This happened to me as well. I found out that I had the VI open in a 2nd instance of Labview. So I couldn't copy from a VI running in one instance of Labview to another instance of Labview.
Message 7 of 9
(3,501 Views)
Same questions as 7 years ago.
"Could you list the exact steps you go through to produce the problem?"
And a couple of new ones: what OS and what version of LabVIEW?
Mike...
PS: For future reference, post that simply say, "Ooh, Ooh, me too, me too" are seldom helpful.
LabVIEW Champion
Message 8 of 9
(3,468 Views)
I faced with the same problem as well. One VI was run as admin, but another one not. That was the reason in my case that after copy/paste code appeared as image
Message 9 of 9
(2,527 Views)
