04-20-2006 02:20 AM
04-20-2006 03:31 AM
04-20-2006 03:57 AM
04-20-2006 10:18 AM
Well, you may be able to assume the force is linear (spring equation F=Kx). With no pressure on the pedal, I am guessing the output is 0V and with full travel of the pedal, 4V.
If you have a force gauge (or scale?) available, use it to press on the pedal until you get 4V out and read the gauge. Caution though, you can only interpolate up to the travel of the pedal, any more and it's probably `non-linear. You can get better accuracy if you plot more than just the force at 4 volts, say 0.5, 1, 1.5, 2....4.
Then just crunch the data to derive an equation to calculate force based on teh voltage read.
May the force be with you
