10-24-2010 07:53 PM
Can any one explain me how to get back alphabets from ascii codes
10-24-2010 08:00 PM
i have to convert this into alphabets
5k¥c¿qWX¾Ò}P?‹&:
12‘YË‹Îçü¹U‚ñ@–Úç'ˆÓ&
125k¥c¿qWX¾Ò}P?‹&:
12‰ù#Äܧ)‹>23E…PØÝß) 12
10-24-2010 10:57 PM - edited 10-24-2010 10:59 PM
Your question is not clear. What do you mean getting alphabets from ASCII codes? Do you have an array of bytes coming in? If so, the Byte Array to String function (in the String >> Conversion palette) can give you the characters.
I also don't understand your follow-up post. What is that VI supposed to show? It's just a VI with a front panel indicator.
10-25-2010 12:30 AM
I am trying to get inverse for this block diagram
10-25-2010 07:09 AM
Often hashing algorithms (e.g. MD5) are irreversible by design. Meaning there is no inverse due to the mathematical calculations performed. Without documentation detailing what algorithm that is it will take someone a very long time to figure out 1) if reversing that is possible and 2) how to do so
10-25-2010 09:00 AM
In that case, you've already asked this question, and are already being helped.: http://forums.ni.com/t5/LabVIEW/inverse-of-hash-function/m-p/1286528
Please do not start multiple threads asking the same question.
