Hello yaauldgoat,
Thanks for your question on how to get your loop rates running faster. I've opened up your code and there is one thing that will be seriously slowing down you loop execution rate.
The 'Write LVM File' express vi contains inside it the functions to open the file, write to it and then close it again. This is happening every time you go around the loop. If you think of when you open up a file in Microsoft Word or something, it often takes a while - sometimes a few seconds. While LabVIEW will probably open the file quicker than that, it will still take longer than the 5 - 10 ms you want your loop to go round at.
To solve this issue you really have two options. The first is to store up the data as you go round and round the loop into an array, and then when you are finished acquiring data, stop the loop and write the whole lot to the file at the end. The other option is to open up the file before hand and then leave it open while you go round and write the information to it, each time just appending the information to the end and then when you have finished, close the file off. I would say that this second option is the best one and I have modified your example to do this.
Hope this helps,
Peter H
NIUK
