08-27-2015 04:41 PM
I want to use Write to spread sheet function inside while loop but I do not want to write all the data sets. I want to have an icon in fron panel when I click it enables the write function for one time. I tried with if function but I need to do another click to disable the write function. Any simple idea?
08-27-2015 04:54 PM
Did you even make an attempt?
08-27-2015 05:43 PM
08-29-2015 07:12 AM
here is the VI I coded. It works but I have to switch the if case my manually while I want it to switch automatically after one iteration.
08-29-2015 09:52 AM
Okay, we are back on track.
As stated above, you have the wrong mechanical action. You have it set for Switch when pressed. That means you click to turn it on, and then have to click to turn it off.
You want Latch when released. Then you click to turn it on, and it will pop back up automatically to off once the control terminal is read.
The difference between when pressed vs. when released is that when pressed means it becomes true when you click down on it. When Released means it becomes true when you let off of the mouse button after pressing down.
When Released is generally the preferred behavior and matches the way most buttons work in the operating system. It gives you a chance to slide off the button and release the mouse without it triggering in the event you made a mistake by pressing down on it to begin with.
Learning the mechanical actions of buttons is a basic LabVIEW lesson.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
08-30-2015 01:59 PM
I learnt LabView on the go so I am not suprised if I missed some basics. Do you think IF structure or event structure is the way forward?
08-30-2015 02:09 PM
There's no such thing as the IF structure. So, that's definitely not the anwer.
If you use the correct mechanical action, you'll do fine with the Case Structure. Until you understand how this works, you shouldn't take a step into the Event Structure. Understand the more basic concepts before trying to use the more complex ideas as they tend to build on each other. If you're able to wait for events in an intelligent way within the architecture you've built, the event structure will be more efficient.
08-30-2015 03:39 PM
Can not the evenet be clicking an icon on the front panel?
08-30-2015 04:43 PM
Yes. But event structures are intended for code to wait until an event happens.
You don't need that for your code since you want your code to run continuously and only have a decision as to whether to log it or not.
08-30-2015 05:52 PM
Do you think the state machine is the best solution?
