continuously update time stamp on main panel
I am trying to continuously update/show the time stamp based of a fixed starting point.  I made a SubVI, to accomplish the task, however, how can I go about using this subVI into a main program?  Alternatively, how can I continuously update the timestamp on the main VI?
Any help will be greatly appreciated.
hiNi.
Message 1 of 9
(3,247 Views)
Can you convert your library to 2012? thanks
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 2 of 9
(3,234 Views)
I’m Unable to check your sample VI (I don’t have 2013 in my PC).
Check this. I hope this will help You.
Munna
Message 3 of 9
(3,226 Views)
Are you on a MAC or are you looking for Time to XL.vi?  (The Time constant does not travel well, reset it to your local time)
"Should be" isn't "Is" -Jay
Message 4 of 9
(3,217 Views)
Hi hiNi,
I'm not sure to have understood your request.
Does this code answers to your question?
Message 5 of 9
(3,195 Views)
I have converted the files to LabVIEW 2012.
I am bascially trying to update the time stamp in the Main.VI every second.  The time stamp has to start from a default setting of 10pm then update from that point until the program stops.  The subVI by itself works fine, however, in the Main.VI, it does not update the time stamp.
Alternatively, is there a more efficient way to have the time stamp update every second in the Main.VI as the program is running, given a default start of 10pm?
hiNi
Message 6 of 9
(3,149 Views)
Sorry,
Here is the program that I need help with to get modified.
hiNi.
Message 7 of 9
(3,136 Views)
Why you want to read time stamp from Subvi. If you’re not doing anything in subvi (except time) then there is no use. You can simply update your time in Main VI ( as per my previous post).
Please check this VI. I hope this will help you.
Munna
Message 8 of 9
(3,122 Views)
You want to display an absolute time that has no relationship to the actual time? That sounds useful.
Message 9 of 9
(3,111 Views)
