continuous reading agilent 34970a error 113
I have been trying to use labview to take continous temperature readings from a K type thermocouple and an agilent 34970a daq and then graphing the changes in temperature.  I think this should be a pretty easy application, but I have been using the 34970a intsrument driver.  Anyways, after a minute or so of running correctly my agilent 34970a gives me an error message - 113 error.  Here is my simple coding.
(4,548 Views)
You don't have a loop so you can't be taking more than one measurement. Do NOT use the run continuous button.
The error code is described in the manual.
(4,534 Views)
so I tried it with a while loop and a stop button and it still gave the same error.
(4,528 Views)
Accepted by topic author tim21
And did you look up the error?
(4,517 Views)
