06-02-2015 09:01 AM
I have thid vi for continous data read from keithly 26XX. It is not saving any data in the file. I am unable find the error. Can anyone help me?
Sudipta
06-02-2015 09:13 AM
Have you tried SourceMeter2600 with the various Options in a "reasonable" order, and do they work without giving you errors? This will tell you (as I'm sure you know) if your GPIB command syntax is correct.
The problem with Continuous Read include:
06-02-2015 09:16 AM
You are opening the file again and again on every loop iteration. Move the open file VI to before the loop and pass the reference in through a tunnel. Also put a close file VI behind the loop so it closes the resource after the loop ends.
06-05-2015 01:38 AM
Bob,
IUs this what you asked me to modify? May be I am still missing something. I tried to follow your instruction and modified continuos read.vi file
Please have a look and suggest
06-05-2015 01:39 AM
NIquist
I have tried as you suggested. But where do I put close vi behind lop?
Please have qa look in the program once
06-05-2015 05:48 AM - edited 06-05-2015 05:48 AM
560092 wrote: But where do I put close vi behind lop?
This is a typical setup for a write to disk setup.
