connector pane full LV 2010
I can't add no more terminals in my pane. How to overcome this?
Message 1 of 10
(2,814 Views)
How many terminals do you have?
If you are using all that LabVIEW can provide you (the most dense pattern has 28 terminals), then you are trying to do too much in that subVI.  Have you tried bundling related wires into a cluster to pass into the subVI?
Message 2 of 10
(2,811 Views)
If not, do you know how to change the connector pane? It's in the LabVIEW Help: http://zone.ni.com/reference/en-XX/help/371361G-01/lvconcepts/icon_and_connector_pane/
Message 3 of 10
(2,804 Views)
If so then don't change it. Nearly all of the time it is best to use the standard connector pane. If you are out of terminals it is time to learn about clusters.
LabVIEW 2012
Message 4 of 10
(2,795 Views)
You're right. Clusters is the way to go now...
Message 5 of 10
(2,777 Views)
How to send a cluster with references from a top VI to a sub VI?
Message 6 of 10
(2,768 Views)
Use a bundle node, create an indicator from its output, then move the indicator to the subvi, change it to control and connect to the pane.
Paolo
Message 7 of 10
(2,763 Views)
Hi Jovmo,
I guess this will help.
Nitzz
Kudos are always Welcome;))
Message 8 of 10
(2,756 Views)
Hi JoVMo,
If you want to do this same with VI references, you can check the attached VI. Download both VIs and run A.vi. It calls the cluster values from B.vi.
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
Message 9 of 10
(2,753 Views)
That's a nice tip NitzZ... Passing data without a connector...
Message 10 of 10
(2,749 Views)
