11-25-2014 10:04 AM
I have created two labviews that runs by itself. The first labview interfaces the movements of a knob. In the second labview, I simulated dynamics of a nuclear power plant into it. I am getting inputs on my frst labview and I want to connect it to second labview where it has a scope for the control rod position. I insterted the image below.
11-25-2014 10:08 AM
11-25-2014 10:22 AM
Yes - a simple solution is to have a local variable from your VISA read and put it in your Simulation loop.
I think you might have to be careful about your simulation parameters - I think you'll need to run the simulation loop in real-time for what you're doing to make any sense?
11-25-2014 10:23 AM
I only simulated for the output I needed not the whole thing.
I am confused on when you siad "slide"
11-25-2014 01:47 PM
The slide control. Up near where it says "Control Rod Position".
11-25-2014 01:48 PM
11-25-2014 01:51 PM
What are "two LabVIEWs"? Are these individually build executables or are both running in the main LabVIEW instance?
