02-22-2013 12:10 PM
Is there a particular reason some SIMX CD vi's show up in my WINDOWS 7 EXPLORER as being compressed? For example, see the output below from the cmd.exe compact command:
Listing C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\addons\Control Design\_Implementation\SIMX CD Discrete Stochastic State-Space (External)\
New files added to this directory will not be compressed.
24319 : 24319 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External).ctl
10025 : 10025 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External).xnode
40532 : 36864 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_AdaptToInputs.vi
26889 : 26889 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_Bounds.vi
29761 : 24576 = 1.2 to 1 C SIMX CD Discrete Stochastic State-Space (External)_BuildPopup.vi
28975 : 28975 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_cfgCallbacks.vi
37450 : 32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Compare.vi
25862 : 25862 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_DisplayName.vi
35938 : 32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_DoubleClick.vi
31803 : 31803 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_Feedsthrough.vi
36399 : 32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_GenerateCode.vi
27975 : 27975 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_GrowInfo.vi
34119 : 28672 = 1.2 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Help.vi
16534 : 16534 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_HelpMap.vi
26200 : 20480 = 1.3 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Image.vi
30113 : 30113 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_Initialize.vi
7923 : 7923 = 1.0 to 1 C SIMX CD Discrete Stochastic State-Space (External)_L10N.vi
39218 : 39218 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_Message.vi
44461 : 40960 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_ModeSelect.vi
43162 : 43162 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_SelectPopup.vi
35619 : 32768 = 1.1 to 1 C SIMX CD Discrete Stochastic State-Space (External)_Size.vi
27764 : 27764 = 1.0 to 1 SIMX CD Discrete Stochastic State-Space (External)_Terms.vi
28414 : 24576 = 1.2 to 1 C SIMX CD Discrete Stochastic State-Space (External)_UpdateState.vi
Every other vi is compressed. I attempted to decompress them & it appeared to work, but then it reverted back. This also happens in some other directories as well, but this is a representative example Again, I used the command COMPACT which the following link provides:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/compact.mspx?mfr=true
Solved! Go to Solution.
02-25-2013 06:01 PM
Just to be sure, is this an NTFS formatted directory? Also, are you attempting to decompress the individual files themselves, or the folder at once? Per the documentation, changing a folder compression state doesn't always affect the compression of the files within. Have you tried the command that should compress/uncompress every file on a specified volume?
02-26-2013 10:51 AM
I think I found the solution. I was unaware that ther was an option for compression within PROPERTIES for a particular folder. All I have to do is check/uncheck the option as long as I permissions that allow it.
