08-12-2013 03:23 PM
When compiling my fpga vi file, I got the following error. It is a crio 9076, with module 9402 and 9463. I am using LABVIEW 2012 sp1 f3, NI RIO 12.1, xilinx 13.4. Does anyone know how to resolve this issue? I have seen similar questions on the Forum, but haven't found the answer.
Thanks a lot.
Quan
Error -61499 occurred at
niFpgaCompileWorker_AnalyzeTimingViolations.vi<-niFpgaCompileWorker_AnalyzeTimin
gPaths.vi<-niFpgaCompileWorker_CheckForErrors.vi<-niFpgaCompileWorker_JobComplet
e.vi<-niFpgaCompile_Worker.vi:1
Possible reason(s):
LabVIEW FPGA: An internal software error in the LabVIEW FPGA Module has
occurred. Please contact National Instruments technical support at
ni.com/support.
Additional Information: Traceback (most recent call last):
File
"./objects/lvfpga_dist/win32U/i386/msvc90/release/root\resource\RVI\TimingViolat
ion\scripts\niFpgaTimingViolationMain.py",
line 280, in <module>
NameError: name 'constraintDict' is not defined
08-13-2013 01:25 PM
Hi Quan,
Did you try the steps in these KB's?
http://digital.ni.com/public.nsf/allkb/DEC13DBCC27C6D7D862577D9006888C5?OpenDocument
- optimize timing
http://digital.ni.com/public.nsf/allkb/0621DAF92B1731138625715E0075A702?OpenDocument
- delete a corrupted dll
Additionally, if you try to compile this project on a different development computer, do you get the same error? It is possible your installation of LabVIEW FPGA became corrupted and LabVIEW or LabVIEW FPGA need to be reinstalled.
08-13-2013 09:09 PM
Hi Joey,
Thanks for your suggestions. Indeed, it is very likely to be an FPGA module problem. I uninstalled everything (FPGA module, real time module, and xlinx) and did a clean reinstall and it worked!
Best,
Quan
