Reply
comparing time
comparing time
I want to compare the time to display working shift like Morning 7:15 to 14:00 is A shift and 14:00 to 22:30 - B shift . Please some one give the solution.
Thanks in advance
Anilkumar
(227 Views)
Re: comparing time
You could try this:
Beginner? Try LabVIEW Basics
Sharing bits of code? Try Snippets or LAVA Code Capture Tool
Have you tried Quick Drop?, Visit QD Community.
(218 Views)
Re: comparing time
Anilgk wrote:
I want to compare the time to display working shift like Morning 7:15 to 14:00 is A shift and 14:00 to 22:30 - B shift.
What should the result be for times before 7:15 or after 22:30? Please provide a complete problem specifications. Smiley Wink
(216 Views)
Re: comparing time
Ignore this post, I though Altenbach was asking a question, not making a request!!
Wes Ramm, Cyth UK
CLD, CPLI
(205 Views)
Re: comparing time
Wes Ramm wrote:
In this case, the value for the resulting string is limited to what the two "Select" primitives, linked in series, can do.
Yes, the code by .:aCe:. is an over-interpretation of the incomplete problem specification by Anilkumar. It was not specified what should happen in the exception case. In any case, I am sure there is a significantly simpler solution. Smiley Wink
(198 Views)
