07-08-2015 10:05 AM
I have a table with 3 columns. one of the column contains time stamp at specific intervals (eg 2 min intervals). this is constanly updated table from a database using SQL. the other column has values corresponding to that timestamp.
The problem is :
I want to compare the current time with the table and use the corresponding value if the time stamp matches. If it does not match, I want it to run continuously and wait until the timestamp matches and then take the value. This value will be used to execute othe fuctions. I do not know how to compare it and how to make it run continuously in a while loop making it wait for each time stamp and take the value.
I am beginner to Labview and so I am finding it hard to solve it.
Kindly help me solve this ASAP.
Thanks in advance.
07-08-2015 10:26 AM
You'll need to convert this into LabVIEW TimeStamp values. There is a scan from string option to do this, or you might be able to format a READ SPREADSHEET STRING operation to handle it.
In any case, if you have the table value in a TimeStamp variable, you can compare it directly to the current time. You probably should NOT check for equality, since a TimeStamp value has microsecond resolution, the chances of a match are slim. But you can subtrtact the two TimeStamps and see if the result is < +/- 1 sec, for example.
The best thing you can do is to break your problem down into simple operations.
I find it helpful to write them down, in pseudo-code:
LineFromSQL = Get line from database
TimeFromSQL = Extract time from LineFromSQL
TableTime = Convert to TimeStamp (TimeFromSQL)
Ready = FALSE
repeat
If NOW >= TableTime
Ready = TRUE
else
Wait (1000 mSec)
until Ready
Extract Other Data from LineFromSQL
Do other Functions (Other Data)
Blog for (mostly LabVIEW) programmers: Tips And Tricks
07-08-2015 12:07 PM
Kindly show us the code you have developed. Be sure to post code (we hate pictures of code, which are hard to execute unless you post them as Snippets).
07-08-2015 12:27 PM
Hi Bob,
I have attached the code. But it is only a code which gets the table from SQL. I think you need to create a similar DB inorder to run the Program.
I am also attaching pictures just for reference or to make the code more clear. Please bear with me.
I want ot use the value of the corresponding timestamp after comparing with the current time. This should happen every 2 minutes as per the present program. I will change it to 15 minutes after the proper solution is found.
Thank you very much for the help
07-08-2015 12:35 PM
The code you posted has nothing to do with the question you asked.
Do you have any code pertaining to the time-matching question?
Or are you hoping someone else will do it for you?
07-08-2015 12:43 PM
Like i told .. I only have a table and I dont know the way to solve it then after.
I am not hoping for someone to do it rather hoping someone can show the way to do it, in a way I can understand as a beginner.
07-08-2015 12:55 PM
Did you attempt to break it down into words, as I suggested above?
It might not work for everybody, but it works for me.
The actual writing (typing) of it forces me to think about the steps needed.
