03-16-2016 08:44 AM
Hello
I'm following this guide in particular: LabVIEW FPGA Sample Project - But i am also experiencing the issue in all other projects that i do
To set the FPGA for "Run when loaded to FPGA" i must open the build specifications as shown here
However, when i do this i encounter the following error:
The full error text says:
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
NI-488: Nonexistent GPIB interface.
Complete call chain:
Get LV Class Default Value.vi
AB_UI_Initialize_Framework.vi
AB_UI_FRAMEWORK.vi
niFpgaBuild_Item_OnDoProperties.vi
niFpgaComp_Item_OnDoProperties.vi
niFpgaComp_Item_OnDoProperties.vi.ProxyCaller
LabVIEW attempted to load the class at this path:
<Empty Path>
Even if i try to redo the FPGA Main from Build Specification > New > Compilation I can check the property "Run when loaded to FPGA" - but am i not able to re-open the properties after it has run? I get the same error.
Solved! Go to Solution.
03-16-2016 09:39 AM
I also noticed that in my project explorer i do not have the FPGA icon for the build specifications, but instead i have a questionmark like this
Does this indicate anything regarding the error?
03-16-2016 11:09 AM - edited 03-16-2016 11:11 AM
Do you have the FPGA toolkit and CompactRIO drivers installed? If you look in MAX under software, do they appear under the version of LabVIEW you have installed and/or the software list? The question mark in the build specification usually indicates that the FPGA toolkit isn't installed/licensed correctly.
03-16-2016 11:55 AM - edited 03-16-2016 12:00 PM
I have both Compact RIO drivers and FPGA Module installed for LabVIEW 32-bit.
However, the FPGA toolkit you are talking about. For the compiler I have downloaded and installed just the LabVIEW FPGA Module Xilinx tools. Is there something extra that i need?
Edit: Searching on google for the "FPGA Toolkit", i found the LabVIEW 2015 FPGA Compile Farm Toolkit - which i haven't installed. Is that what you are referring to?.
03-16-2016 12:50 PM
Sorry - yes, I meant the FPGA Module - it should be installed under 'LabvIEW 32-bit' in MAX.
To build an FPGA VI - you need to either use the compile farm (to compile the FPGA on NIs servers) or the Xilinx tools (to compile locally on your computer).
03-17-2016 02:39 AM - edited 03-17-2016 03:07 AM
I have FPGA Module for 32-bit LabVIEW
Edit:
This morning i saw that i had an update for
LabVIEW 2015 FPGA Module Xilinx Tools Vivado 2014.4 f1 Patch
When trying to install i get the following error
When i search for "Ni LabVIEW FPGA Xilinx Vivado HLS 2015" all i find is this download page which is the exact tool that i have already downloaded and installed.
03-24-2016 02:26 AM
I solved the issue by uninstalling all National Instruments software, and reinstalled in the following order:
LabVIEW 2015 (32-bit) http://www.ni.com/download/labview-development-system-2015/5308/en/
LabVIEW 2015 (64-bit) http://www.ni.com/download/labview-development-system-2015/5314/en/
LabVIEW 2015 FPGA Module http://www.ni.com/download/labview-fpga-module-2015/5461/en/
LabVIEW 2015 Real-Time module http://www.ni.com/download/labview-real-time-module-2015/5451/en/
LabVIEW 2015 FPGA Xilinx Tools http://www.ni.com/download/labview-fpga-module-2015/5492/en/
NI CompactRIO 15.0 http://www.ni.com/download/ni-rio-15.0/5363/en/
After i was able to update the urgent f1 patch for LabVIEW 2015 FPGA Xilinx Tools in the NI Update service manager and the issues have been fixed.
