09-21-2006 02:43 AM
I have some questions concerning Profibus communication between a Compact Field Point system and a Siemens PLC.
The following hardware is used:
NI cFP 2120 controller
Siemens S7 314 MPI
Has somebody tried to read data from a Siemens PLC over the RS485 ports with profibus?
If yes, could we get the (Siemens) command set so we can try to retrieve data from the PLC (using NI-VISA).
Or has somebody already programmed a solution, could we then have an example of how it has been programmed.
Has somebody solved this problem of communication in a different way? What was the solution and how much time / money did it take.
Hope someone could help me with this problem.
Already thanks for the effort.
09-21-2006 08:25 AM
