comments on vi
i have a lv project with a main vi.I copied it to my laptop,instead copying the whole project,i copied only the vi by mistake.i added all the comments for the code in the vi.now when i copy the commented vi back to the project folder,it is not happening.
please help me to fix this.
Message 1 of 12
(3,502 Views)
Hi krupa,
what exactly is "not happening"?
Message 2 of 12
(3,492 Views)
When i copy the main vi that has comments,to the lvproj folder,the old vi is not overwritten by the new one.
Message 3 of 12
(3,482 Views)
Hi krupa,
why can't you overwrite the VI?
Don't you have access rights to that folder/file?
What happens when you close LabVIEW and restart it. After restart open the VI and/or the project…
Message 4 of 12
(3,466 Views)
use save as and then select duplicate hierarchy to new location
Message 5 of 12
(3,461 Views)
When i close,reopen it(vi,lvproj)..it is opening.i do not see any error..its working fine..just the copying is not happening
Message 6 of 12
(3,458 Views)
As i am copying from other location,the path seem to have changed.
how can i correct this??
Message 7 of 12
(3,431 Views)
Hi krupa,
lesson learned: don't copy single VIs from a project from one computer to an other!
How to correct? Follow the advices in the dialog shown in your image…
Message 8 of 12
(3,396 Views)
did you use  save as and then select duplicate hierarchy to new location?!
after that just close old vi and open from new location
Message 9 of 12
(3,385 Views)
Another mess that proper Source Code Control would have prevented.
It looks like you tried to open up the VI from another location.  Why were you unable to copy the file back overtop where you originally copied it from?  Sounds like a permissions issue.
GCentral
Message 10 of 12
(3,367 Views)
