09-03-2013 09:47 AM
You need to post a VI that actually has values. Go to the Edit Menu and select 'Make Current Values Default'. Save the VI. Attach it.
In any case, the delimiter control is NOT set for \ Codes Display. That is the important one.
I've tried with a ,\00 delimiter and it worked for me.
09-03-2013 09:58 AM
Thanks!
The delimiter was constant and I then changed ti to a control. After setting the control for Codes Display as well. It works!
09-03-2013 10:01 AM - edited 09-03-2013 10:01 AM
tian66 wrote:The delimiter was constant and I then changed ti to a control. After setting the control for Codes Display as well. It works!
You could have set the diagram constant to \-display instead. 😄
(If you leave it as control (not recommended!), you need to make sure to make current value the default and re-save, else the value is lost once you close LabVIEW.)
09-03-2013 10:04 AM
I have changed it to a constant again.
I learned a new trick from Dennis (Make Current Value as Defalut). The stored values will be still there after reopen the VI. It is helpful for my programs!
Thank you two!
