07-27-2006 03:43 AM
07-27-2006 03:53 AM
Hi
I usually create a constant of this cluster, wire it to a bundle by name node, wire the necessary values and wire the output to the cluster terminal.
07-27-2006 03:56 AM
07-27-2006 06:25 AM
It would be better to wire the cluster value than a constant cause the unwired entries will take the value of the constant. If your use a local var of your cluster, the unwired entries will keep the same value.
Yann
07-27-2006 06:28 AM
