clumper.cpp
Does anyone have ideas what may cause LabVIEW to fall over and report an error in clumper.cpp?
The forum search provides no clues...
edit: LV 8.5.1 running WinXP Pro SP3
Message Edited by nrp on 04-28-2008 11:17 PM
(2,316 Views)
Did you try using the investigate error dialog? It sometimes sends you to the proper place.
<guess>
That's the code that takes your compiled code and decides when to execute each piece ("clump"). A force compile might help, but if LV would just generate the same machine code, it probably won't help you.
</guess>
___________________
Try to take over the world!
(2,298 Views)
No, I didnt bother investigating it at the time, I was too angry at LabVIEW!
Thankfully it appears to have been one of those random LV crashes (we have become so accustomed to) that doesn't happen very often Smiley Surprised
(2,267 Views)
