08-22-2014 07:55 AM
Hello my people! 😉
I am a little confused here...
When starting a main VI i wanted to open a dialogu box - no problem so far. Actually the dialogue box did not match my needs because i want to insert different fonds etc. and pictures into it.
So i made a VI with the text and pictures in it (lets call it "VI dialogue") and i want to open that VI if my main VI startes.
With a button in the "VI dialogue" i want the dialogue to close and the user resumes to the main VI.
Acutally i have no idea how to handle this 😕
Could somebody give me some hinds on how to do this?
Solved! Go to Solution.
08-22-2014 07:58 AM
Create a VI which opens front panel when called.
08-22-2014 08:18 AM
There's a VI property for Open When Called and another one for "Close When Done (If Originally Closed). Both of those are in the VI Appearance property page.
08-22-2014 02:05 PM - edited 08-22-2014 02:06 PM
If you go into the VI properties you can set the appearance to "dialog" and I believe that handles all the showing, hiding, and modal stuff. I usually start with that template and then choose customize to fine-tune it.
[edit] oops, didn't realize cross posted something similar. cross's post is the manual way to do it. The "dialog" option is a template that includes this behavior. [/edit]
08-25-2014 02:49 AM
Thanks for your help! i got it 😉
