You can close the VI's FP by using VI server techniques. Open a reference to the VI (use Open VI reference from the Application Control Palette, do this outside the loop) and wire that reference into a property node. Then, select the FP.Open property, place the node after the loop and wire F into it. When the loop finishes running, the FP will be closed.
___________________
Try to take over the world!
