check if file or folder
This is the modified VI.
Message 11 of 23
(1,300 Views)
Is this VI running on the windows computer or on the sbRIO RT system?
If you are trying to create a file or folder on the sbRIO target, a syntax starting with "C:\" is incorrect.
Message 12 of 23
(1,283 Views)
It also depends on the LabVIEW version. Since the original VI is in LabVIEW 2011 I believe your statement may be correct. In newer realtime targets they actually create simlinks such as /c/ni-rt and similar pointing to the actual Linux directory which makes a path showing C:/something on Windows translate correctly into /c/something on the NI Linux realtime system.
With sbRIO being VxWorks based and using LabVIEW 2011 your statment is however most likely true.
Rolf Kalbermatter
My Blog
Message 13 of 23
(1,270 Views)
You were all right. I had used "create folder" on the sbRIO target. When I created a new vi under Windows target (My computer), I got the log file.
If I want to create on sbRIO target, what should the syntax be?
So will the log file be stored in sbRIO's memory? How to access it?
Message 14 of 23
(1,244 Views)
Hi kdm,
use FTP access to read files from sbRIO internal "hard" drive…
Message 15 of 23
(1,231 Views)
Or create a shared folder on your main computer and let the sbRIO write to that folder using the network path.
GCentral
Message 16 of 23
(1,217 Views)
I am able to access the file now through FTP. Thanks Smiley Happy
But I am not able to view continuously (simultaneously). That is, everytime I have to refresh my page to view the newly logged data.
Also, the data does not appear column wise (I mean the respective data is not under its respective column) even though I used a tab constant between them.
What could be wrong?
Here is the vi.
Message 17 of 23
(1,214 Views)
I don't think it will make any difference, but you shouldn't use Build Array when building up your report string.  You should be using Concatinate String.  I'm not immediately finding anything else that would cause the columns to be off.  Do you have an example of your output?
GCentral
Message 18 of 23
(1,208 Views)
Oh yes! Silly me. It should've used concatenate string.
Thanks.
Message 19 of 23
(1,202 Views)
GerdW - you are "newbie shaming" for no reason. In fact BOTH of the below methods are correct. If as you say "You create a file path by using string constants. THAT'S PLAIN WRONG! Use path constants whenever you want to handle paths!" were in fact even remotely true, why would "String to Path" even exist? Yes, your way is more efficient and what a seasoned LabVIEW programmer might do; but shaming someone AND providing incorrect information in the process simply because they did something a different way than you think is correct is both inaccurate and unfair. Both ways work. You should apologize. I know this is an old thread, but I felt compelled to comment.
undefined
Message 20 of 23
(713 Views)
