As you found it, it is not possible to change a chart from overlay to stacked during execution. Using 2 charts and making only one visisble is a simple workaround. To maintain the plots continuity, there are two possible solutions :
1/ copy the data from one chart to the other when switching charts
2/ simply plot the data on both charts at the same time.
Solution 2 seems to require more memory. However, a dual 1000 points (Dble precision floats) takes only 16 ko of memory space...
CC
Chilly Charly (aka CC)
E-List Master - Kudos glutton - Press the yellow button on the left...
