changing sub vi pop up
Is there a way that when clicking on a sub vi on my block diagram I get the sub vis block diagram instead of its front panel?
Message 1 of 9
(4,404 Views)
Accepted by topic author pathare535
I assume you mean when you are in "Development mode" and creating (or modifying) LabVIEW code on the Block Diagram.  Clicking on a sub-VI on your block diagram is equivalent to clicking on it in LabVIEW Project or in Windows Explorer -- it opens the sub-VI in LabVIEW, which opens the Front Panel.  I don't think you can change this (but am willing to be proven wrong) -- I think this is the intended, designed-in, and logical behavior.  It only takes a Ctrl-E to get to the Block Diagram ...
Message 2 of 9
(4,399 Views)
Yeah, I get that its a logical step that the front panel is displayed then press ctrl-e to get to the block diagram, but when Im going down a few levels of sub vis my monitors get really cluttered. I'd prefer it was the other way, I press ctrl-e to see the front pannel.
Thanks though
Message 3 of 9
(4,394 Views)
You can "declutter" monitors by minimizing (the little "-" sign in the upper right corner of the Window) the Front Panels you don't want to see.  But you are correct -- the screen can get "filled with VI parts" making it difficult to navigate.  One thing you can try is the Find feature (Ctrl-F) -- if you have, say, 20 VIs in memory and they are all on the Screen, and you want to see where your "Open Acquisition" is called, just Find "Open Acquisition".  [Hmm -- this might only find where Open Acquisition is called, not the VI itself, but you can also quickly find it by clicking on the LabVIEW Icon on the Task Bar which brings up an organized list of all the LabVIEW Windows that are currently open -- just click the one to which you want to jump).
Message 4 of 9
(4,389 Views)
You can Ctrl+Double Click on the subVI and the block diagram will open up.  However, the front panel will also be opened.
GCentral
Message 5 of 9
(4,379 Views)
See?  You always learn "something new" on the LabVIEW Forums!
Message 6 of 9
(4,376 Views)
The front panel will be opened UNLESS the VI is running in a subpanel, then only the block diagram will open.
Mike...
PS: I know this isn't the case the OP was asking about, but it was too good a tip to pass up...
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 9
(4,351 Views)
Use Ctrl+Double Click on SubVI
Message 8 of 9
(4,277 Views)
USe the  Ctrl+ Moue Left Double Click on SubVI Block  will appers 1 st..
NI CLDlabview-programming-fundamentalslabview-environment
Message 9 of 9
(4,272 Views)
