change array size and delete duplicate row
I am running a program that does a for loop 3 times.  In each loop, data is collected for x and y points (10 in the example provided).  How can I output the array with the 30 points in a simple 2D array (size 2x30)?
Also, from the array, how do I delete duplicate rows that contain the same x-value?
hiNi.
(2,629 Views)
Right-click the output tunnel of the outer loop and change the mode to concatenating (right-click...tunnel mode...concatenating). Change your current output array to 2D and resize as needed.
Are rows with the same x-value always adjacent?
(2,587 Views)
THANK YOU for solving my first issue!  Attached is the data set that contains the duplicate entries for the x-axis values.  The y-axis value may be different, but not the x.  I would like to delete the 2nd row that contains the same x-value.
Here is simple example of my input and desired output:
IN:
28.512000 -115.310532
28.812000 -86.937660
29.112000 -116.877052
29.412000 -87.223625
29.412000 -111.349045
30.012000 -86.510780
30.312000 -112.048187
OUT:
I am thinking of comparig the last x-axis value to the current one, and if it is the same, then not parse that row.  The attached VI is as far as I got.
Any help will be greatly appreciated.
hiNi
(2,543 Views)
Accepted by topic author hiNI
It probaibly would have helped to attach a file that has consecutive duplicate rows. 😄
Here's one simple solution.
(2,532 Views)
