05-02-2008 11:26 AM
05-02-2008 11:37 AM
05-02-2008 11:43 AM
You might be able to use an event structure and property nodes to make those chage when you change the value of the boolean...
OR an XControl instead of standard boolean with the logic to the transition in the Control itself...
05-02-2008 11:47 AM
How about adding a CR before and after the text?
Ben
05-02-2008 02:04 PM
06-05-2009 06:45 AM - edited 06-05-2009 06:49 AM
Hi all,
I came across the same problem and want to describe it a bit more precisely. When I change the boolean text in the value change event of this button, I notice this unwanted behaviour. But when I set the Bool- text in another frame of the event structure, all works fine. It is the same, if I unset the "Lock Front Panel..." checkmark in the event- structure dialog. For better understanding I attached a example- VI.
Another point is illustrated in the VI as well, whenever I add a "Panel Close?"- filter event, the terminal "Discard" is always shrinked. This seems to be a bug too.See picture below:
Btw. I use Lv 8.6.1.
Greets, Dave
