case structure
I don't know why this is not working ...the attached VI ... Any Idea ?
(2,824 Views)
What's it supposed to do?
Your constant case for "B" has a space after it.  Why are you selecting a 1-element array and reversing it?
Jim
(2,819 Views)
Thank you ... solved 🙂
(2,815 Views)
What does "not working" mean?
I press the run button and it runs just fine and does throw an error, crash my PC, or blow up my monitor.
(2,814 Views)
Done Thank you 🙂
(2,811 Views)
An ambiguous solution to an undefined problem.  I guess it's not worth selecting a post as a solution.  😉
Bill
CLD
(Mid-Level minion.)
(2,784 Views)
This is just one piece of very convoluted code. You could get the same result with significantly less code. Try it. 😄
Why does the output need to be an array?
(2,768 Views)
