case structure append array
Hi there,
I want to fill my array depending if the radiobutton is clicked.
But the array does not grow.
Here is part of my VI.
Message 1 of 12
(4,592 Views)
Hi Xeno,
which "array" do you want to grow?
In general: to "grow" an array you need an older version of the array data, then you attach new values (with BuildArray), then you store the new data set in a wire. (This is called THINK DATAFLOW!)
General hint 2: You store data in wires or shift registers.
This is pretty basic LabVIEW stuff about array handling - did you take the free online resources to learn LabVIEW?
Message 2 of 12
(4,586 Views)
I want to grow append array.and also that the filenames are correctly transfered into the array, but thanks for the hint.test2.PNG
Message 3 of 12
(4,581 Views)
You'll need to maintain the array somewhere.  You'll want to use either a variable of some time or a shift register.  Typically, I'd prefer the latter.
You'll also want to get into the habit now of creating an icon for subVIs you create.  The default icon with a 1 is something that will plague you as you start to develop more complex applications.
Message 4 of 12
(4,578 Views)
I understand what you mean, but I have make nearly a screenshot of the whole diagram and hopefully you will see my problem.test3.PNG
Message 5 of 12
(4,565 Views)
the problem is you still don't use a shift register to hold your array to append…
Message 6 of 12
(4,557 Views)
Please stop attaching screenshots and attach the actual VI. Thanks!
Most of the code makes very little sense.
  • Why is there an event structure inside a case structure?
  • Why are there FOR loops running in parallel that seem to spin as fast as the computer allows, repeating the same operation dozends of time. Wouldn't once be enough? (ever heard of autoindexing? search array?)
  • What's up with all these local variables?
Message 7 of 12
(4,555 Views)
Which problem are you wanting us to see?
You still aren't using shift registers/variables?
You still have default icons?
You have wires running behind your structures?
They're all easy to fix.
1) Create a shift register to maintain your array.
2) Double click on the icon and edit it
3) Right-click on the wire and choose "clean up wire"
Message 8 of 12
(4,554 Views)
Hopefully many suggested the right way to fix your problem.
Intialialising the array with shift register and building the array when required will be one of the easy and simplest method as per as your requirement.
Message 9 of 12
(4,535 Views)
Hey there,
thank you all for your help, I have found a solution. It was yesterday too hot, so my brain was a little bit damaged:)
Here is my vi:
Sry for asking again, but now I have a little problem with the multicolumn listbox, where I want to add string values depending on the radiobutton which works, but no string is transfered into the box.
And the gui:
Message 10 of 12
(4,506 Views)
