03-29-2016 11:44 AM
sir i do not know a lot of about labview . but i am studying about it . i am trying to make a project since 15 days . but i am failing every time and now lost with my knowledge about labview . the project is semi automatic car parking system . here i am using two counters . one for entry of the car and other for the exit of car . if i subtract the no. of exit car from entry cars so i am able to calculate space and able to show it on screen .
but problem is that when i run my program the barrier open and after 5 sec it close as i programmed . but when i increment or decrement counter so again it does not responce . to open the barrier i have to again run the whole programme . that is the limitation of my program .
please help me . i know this is a big bug . '
please help me
i will be thankful to you for this
03-29-2016 11:55 AM
Please include a Snippet of your code, or attach your VIs, so that we can better assist you.
It sounds like you have a dataflow issue if you program is not responsive.
LabVIEW programming is based entirely on dataflow and parallelism. This is incredibly powerful and has lead to its success over the years (coupled with the graphical programming), but is usually one of the first things that new developers stumble over. Here's a simple resource to become more familiar with how it works. The Highlight Execution feature is a great way to watch how your application utilizes dataflow.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-05-2017 12:24 AM
Why "sir"? Females not invited to this party?
07-05-2017 03:39 AM
Sincerely In Respect? - no sexism intended?
