01-09-2014 03:23 AM
Hi everybody,
I want to broadcast video from the camera of my tablet android.
- mode of transfer via bluetooth.
- I need to receive that video in LabVIEW.
I download WOWebcam Lite application for tablet.
This app create a virtual device in my MAX (Measurement and automation Explorer).
First I check whether I can see my android virtual device in MAX and I try grab and snap, but it does not work.
Therefore it can not work in LabVIEW.
Please help me to solve this problem !
I discussed it here: http://forums.ni.com/t5/LabVIEW/Integrating-Android-Devices-Camera-with-NI-Vision-Software/td-p/2481...
Thanks.
Solved! Go to Solution.
01-09-2014 09:54 AM
01-09-2014 03:16 PM
when i connect the device and configure the connection from wo webcam client from pc, the connection rest only 4 or 5 seconds then it close automatically, and the image was black .
Bset regards
01-09-2014 10:46 PM
01-10-2014 07:06 AM
Thank you for your responses.
Your question : Are you getting any error? or simply nothing happens?
- When i connect the device and after that i have this error which is attached below.
- And nothing happens.
Best regards
01-13-2014 12:17 AM
01-13-2014 05:04 PM
First I connect my tablet with PC and the connection work when I send data.
But in the case of image of camera WOwebcam, I haven't any result.
When I connect the WOwebcam based on stapes of connections which explained on "Help" attached with the program, the application didn't work and I haven't any image.
Thanks.
01-13-2014 05:04 PM
Thanks.
02-09-2014 05:02 PM
My problem is solved.
Best regards !
