11-24-2014 01:55 AM
Hello
I now, in the past, labview couldnt zoom in/out (by reading the last topics). is it impossible yet?
I want make a program, that user can zoom in/out page.
Best Regards
Solved! Go to Solution.
11-24-2014 02:40 AM
@behzad1 wrote:
Hello
Best Regards
There's no inherent function for that, but if your application should have that ability you can create it yourself. You can e.g. take a screen capture of your front panel and scale it up and show it.
/Y
11-24-2014 02:51 AM - edited 11-24-2014 02:52 AM
11-24-2014 03:16 AM
@GerdW wrote:
Hi Yamaeda and behzad,
you can load a picture in the 2D picture indicator and set the scaling factor of the indicator using a property node…
So there is an inherent function!
Nice workaround, i like it.
/Y
11-24-2014 06:09 AM
thanks friends
but, we talk about monitoring program as real time. can it scalable?
can we change scale of an object too?
Best Regards
11-24-2014 06:10 AM
11-24-2014 06:32 AM - edited 11-24-2014 06:36 AM
Thanks GerdW.
may you make small example for two object?
Best Regards
11-24-2014 06:40 AM
11-24-2014 11:18 PM
Hi GerdW
May you use a tank that it's scale control by a knob in an example?
Best Regards.
11-25-2014 01:28 AM
