03-25-2013 02:14 PM
All,
I've had this issue for a while, but it only happens on some machines.
Background:
Program: Labview 2012
Development computer: Windows XP
Deployment computers: Windows XP with only Labview runtime environment on it.
During development, all controls function normally. However once deployed as an executable, some computers end up with broken controls. In a numeric control, for example, the user can change it using the increment/decrement buttons, but cannot enter the actual desired number manually. In a text control the user cannot enter anything at all.
This only happens on some machines, and only with some programs. Is there some setting that I need to enable controls?
I have no code examples that can be shared, and anyway it happens with multiple VIs.
All help appreciated.
03-25-2013 02:40 PM
Do you have the LabVIEW 2012 runtime engine in the deployement machine? Are they silver controls and are they typedef?
03-25-2013 02:44 PM
The labview 2012 RTE is included in the installer I created.
The control is not a silver control.
I did find that the property for the control had it set to "disabled." So that's probably it. I don't know how it got set to disabled, though, because I didn't.
