06-21-2014 08:25 AM
I have the full 2013 development system which includes the real time module. I'm trying to use it with the c-9068 for the first time. I'm able to see it in MAX and everything seems fine. When I add it to a project, I can see the modules but I can't connect and see the green light turn on (see image). I also notice it says "features not available" for some reason. I've reset and re-installed software on the cRIO several times with no luck. I also have this happen on my home network as well as my work network. I'm fairly sure all of my software is up to date. What am I missing?
Thanks in advance.
06-21-2014 08:57 AM
How did you detect the modules? Did you added the modules or it automatically detected?
06-21-2014 11:09 AM
I right clicked "Chassis" and selected New module. I then selected each module. It knew what modules where there and it shows the correct slots.
06-21-2014 11:33 AM
After selecting New Modules you selected "Existing Target Devices" or "New Target Devices"? Am just trying to understand what is really happening.
06-21-2014 12:03 PM
I selected existing target or device along with discover an existing target or device. It then lets me select from the three modules I have plugged in.
Thanks for trying to help.
06-21-2014 12:57 PM
06-21-2014 01:34 PM
I've tried it on two different PC's and two different networks. I could have screwed up the host setup on both PC's though.
06-21-2014 10:33 PM
Did you check for software updates/patches?
06-22-2014 08:44 AM
Yes. Here is a screenshot of the software on the crio. My understanding is that since 13.1.1 is black and not gray, it is installed on both the host and target. Please let me know if I am not understanding correctly.
06-22-2014 08:48 AM
