12-20-2006 11:30 PM
12-21-2006 12:09 AM - edited 12-21-2006 12:09 AM
Message Edited by altenbach on 12-20-2006 10:09 PM
12-21-2006 12:35 AM
yup... altenbach is right... i've attached an example... its not the best method of doing it... but hope it gives you a start...
12-21-2006 12:41 AM
thanks guys,
i was just stumbling onto property nodes. so much to learn. thanks again.
12-21-2006 01:58 AM - edited 12-21-2006 01:58 AM
Here's a more streamlined version using a case structure with ranges (LabVIEW 8.0). Also remember that if all cases of a case structure contain the same property node, the property node itself belongs outside the case structure.
(I also made the slide an indicator as apparently desired. ;)) Remember that property nodes are relatively expensive, so it might be worth to place it inside another case structure so it only gets written when the color actually changes, and not with each loop iteration.
Message Edited by altenbach on 12-20-2006 11:59 PM
12-21-2006 02:16 AM - edited 12-21-2006 02:16 AM
Message Edited by altenbach on 12-21-2006 12:17 AM
