can i display continiously a calculated value not a tag in NI hyper trend
(2,729 Views)
Hi:
Ni Hypertrend only displays tags, you will not be able to display calculated value. I hope this helps and do not hesitate to post again if you have further questions.
Rudi N.
(2,712 Views)
Hi..
Can you suggest me how to display tags in NI hyper trend. Right now we are using View Historica data option of DSC to do so but we want to do it programatically,so plz suggest me how can i do this..
 anisha
Message Edited by vijtin on 11-13-2008 11:34 PM
(2,539 Views)
In the 7.0 DSC world, you could create memory tags and write your calculated values to them. Then you had access to these values like regular tags. I haven't used the 8.6 DSC module yet, so I don't know if it still exists.
(2,530 Views)
i m using 7.0 DSC only... i want to log analog tags of I/O type into NI hyper trend for required time duration....can you suggest me how to do that.
(2,511 Views)
