NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
isenhand
can I convert data in a *.td file to ascii?
I have a *.TD file and have recived a requrest to have the data converted to ascii.
Can I do that? If so, how?
Active Participant
ThiCop
Re: can I convert data in a *.td file to ascii?
Hello Isenhand,
What type of file is this file with .td File extension?
Is it a Borland Debugger Configuration File ?
Kind Regards,
Thierry C - Platinum Applications Engineer - NI Belgium
CLD
If someone helped you, let them know. Mark as solved and/or give a kudo. :smileywink:
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
