07-08-2013 12:10 PM
Hello
I have a dll written in VB6 to control some 3rd party hardware
I already tried to use Call Library Function Node but it does not seem to work, after that also I tried to use
Automation Refnum, input then Select ActiveX Class and and locate my DLL but when I select the dll, the following message shows on the screen: The selected file is not a .NET assembly, type library or automation executable.
Keep on the issue I tried to register the Visual Basic DLL on the system through the REGSVR32 command but I got another different message (fbidio.dll was loaded, but the DIRegisterServer entry point was not found. This file can not be registered). It looks the dll I intend to use is very old.
Can anybody guide me on this issue, what other things I can try.
Thank you.
Regards
Solved! Go to Solution.
07-08-2013 04:58 PM - edited 07-08-2013 04:58 PM
What does not work with the Call Library Node?
Unfortunately it can depend how the DLL was created, if it would be a normal DLL with exported functions or an ActiveX DLL. Both have a DLL file ending but are in fact very different beasts. VB 6 definitely couldn't create .Net assemblies so you don't have to try that in LabVIEW.
07-08-2013 06:12 PM
Hi
The LabView collapse when I try to use the Call Library Node, In my understanding according to some comments I saw, it is not possible to use call library node for VB Dlls.
Anyway I already figured out how to control my hardware, I found an update module for Active X controls in the web for my hardware and now my application works perfectly with an ActiveX container and then inser ActiveX object.
Thanky you so much.
Regards
