02-25-2014 10:53 AM
Gerd the timestamp datatype was introduced in LabVIEW 7.0 You need to do it the hard way
02-25-2014 10:57 AM - edited 02-25-2014 10:58 AM
02-25-2014 11:17 AM
yes it is hard since time stamp feature is not available in labview 6.1
so is their any other way to create a calender to make it a easy task?
02-25-2014 11:41 AM
In versions prior to the timestamp datatype the timestamp format specifiers won't exist either. (Sorry Gerd- I had to run off to a meeting and left you with only the bare clue)
By "The hard way" I truely mean you WILL need to depend on building your calander off the elements in a date-time- record cluster. (or a completely new structure of your own devising)
02-26-2014 04:34 AM
In pre-timestamp versions of LabVIEW I used to use an active x calendar control. A quick google will find you a selection.
MC
