02-24-2014 10:31 PM
How to make a calendar in labview 6.1 using RING?.Applying conditions that we select a month suppose feb so it contains 28 days......& same for other months also.
02-25-2014 12:09 AM
Why you want to reinvent the wheel, you can reuse the .NET based control.
If it is a stringent requirement, I would suggest create a X-control.
02-25-2014 02:21 AM
offcourse ..but in labview 6.1 there is no such kind of function.
can i know how to make calender easily in Labview 6.1?
02-25-2014 02:26 AM
Hi priya,
that are two points in one question!
Do you want to have a calendar control in LV6.1?
Or do you want to have it the easy way?
Start by thinking what you need to represent that calendar control.
Then start to think of a state machine approach to handle all the user input to that control.
Does LV6.1 even have the timestamp control as newer LV versions have?
Can't you upgrade to a more recent version of LabVIEW? LV6.1 is outdated the same as WinXP nowadays…
02-25-2014 02:32 AM
i mean that a functionality that user inputs date in dd-mm-yy format from a calender created.
02-25-2014 02:37 AM
02-25-2014 04:55 AM
In english
02-25-2014 08:14 AM
02-25-2014 09:39 AM
As labview 2012 have the timepicker control... i want to create the same in labview 6.1 as it does not have that in built feature
kindly give me the screenshot of solution as creating the whole calender is quite timeconsuming.
02-25-2014 10:21 AM
