06-26-2013 02:15 PM
06-26-2013 04:32 PM
Kudos would be nice
06-27-2013 03:57 AM
Hi alexderjuengere,
Can you please send me the labview.vi file for the segmentation(color mask file).
THank you
06-27-2013 04:49 AM
06-27-2013 08:00 AM
Hi alexderjuengere,
When using k-mean clustering to find the dominant color in an image,for example,if i had given classes as 5,in the array there will 5 colors as output,each time when i execute the code with the same input image file,the colors in the array changes.Do you have any any solution for this or any other method to find the dominant color?.
I have attached the image regarding the change in color in the arrax color while executing the same input image for various time.
Thank you
06-27-2013 01:11 PM - edited 06-27-2013 01:16 PM
hi madhubalan,
k-means in a nutshell:
terminated
compare: http://www.autonlab.org/tutorials/kmeans11.pdf
one quick solution:
have you tried to reduce the number of classes?
K-means is an unsupervised learning technique.
A k-means algorithm works best, if the initial cluster centers ("ground truth" would this be called in supervised learning techniques) are decently guessed by the algorithm or "teached-in" by the user.
I haven't installed this clustering toolkit on this machine, but I think this double-array constant was related to those initial cluster centers:
If this constant is empty, there is an automated guess, I guess.
Alex
06-27-2013 01:20 PM - edited 06-27-2013 01:21 PM
by the way, I prefer this machine learning toolkit, because it also got visualization in 2d (XY Graph) and 3d (3d picture controls)
06-29-2013 05:27 AM
The screw you want detect is evidently quite bright due to it's well-reflecting surface and the chosen illumination.
Total reflex ion causes rather white colors, so the 3 rgb values of those particular pixels will be rather on the right side of your brightness histogram graph.
Speaking of histogram graphs, you should do some exploratory data analyses on your input pictures: http://www.ni.com/white-paper/4158/en/
This will definitely help you to localize the range of your thresholds. Regarding to thresholds: I recommend to use more than one.
Segmentation is a tricky task with real world data.
Alex
07-01-2013 04:17 AM
Hi alex,
I could not able to find any other method for dominant color determination.If you have any method ,then let me know it.
But ,if i use only class 1,then dominant color remains the same for many execution step for the given input image.
This the link for downloading the clustering tool.https://decibel.ni.com/content/docs/DOC-4063
I have attached a vi file for color mask,in this file,how to determine the percentage of dominant color present in the given input image.(i have attached a input image)
Thank you
07-01-2013 04:56 AM
and does this give you the expected result/color? are you fine with this?
now, this sounds to be trivial:
number of dominant color pixel
dominant color in % = ---------------------------------------------
total number of pixel
have you given a try to my previous post at:
http://forums.ni.com/t5/LabVIEW/calculate-color-mask/m-p/2472546#M756827
a will look into your example later this day
Alex
