cRIO9076 & Xilinx Compiler doesn't work
So another update.
This morning i got the RT 2010 SP1 evaluation version from the ni support.
I installed it and tried to compile my fpga vi.
The result is still the same error as mentioned above.
Message 11 of 14
(455 Views)
I uninstalled the whole Labview Software and reinstalled it in following order:
LabVIEW 2010 SP1
LabVIEW RealTime 2010 SP1
LabVIEW FPGA 2010 SP1
N-RIO Device Drivers August 2013
The error from the first post occurs now again.
A screenshot is attached.
Message 12 of 14
(422 Views)
"Bump"
I'm also getting the same error "Porject set family spartan6"
I have the following configuration:
cRIO-9075
LabVIEW 2010 SP1
NI-RIO 3.6.1
LabVIEW FPGA Module 2010 SP1
LabVIEW Real Time Module 2010 SP1
Xilinx Tools 11.5
Knowledgebase says that should all be compatible and working, however...??? Not working. Sad Face.
Help!
Message 13 of 14
(354 Views)
Hey All,
After opening a ticket with NI support, I eventually reinstalled the FPGA Module 2010 SP 1 and the NI-RIO 3.6.1 (in that order), leaving everything else in place.
I was able to compile a Blank FPGA vi and then a simple Digital Input FPGA vi.
I believe the issue occurs due to installing the Xilinx 11.5 tools seperate and/or after the FPGA Module.
Good Luck!
Message 14 of 14
(332 Views)
