11-21-2013 03:59 AM - edited 11-21-2013 04:05 AM
everytime i start to compile an simple vi for my fpga target on the crio9076 i get following error:
Compilation failed due to a Xilinx error.
Details:
ERROR:TclTasksC:project_028: Unknown property value "spartan6" specified for "PROP_DevFamily"
while executing
"project set family spartan6"
(file "C:\NIFPGA\jobs\YYCpvK1_GGlHXpz\synthesize.tcl" line 5)
I tried to compile the vi on another pc with similar software setup, but there was the same result.
And i searched for possible solutions, but i didnt find anything suitable.
I tried to compile another vi from an old project with works with the PCI7833R, here works everything fine.
After a few minutes i get the complete bitfile.
My Software Setup is: Labview 10f2, FPGA 2010, Xilinx 11.5 & Xilinx 10.X Compiler
Thanks a lot for your help 🙂
Greetings,
Ben
11-21-2013 09:17 AM
11-21-2013 12:55 PM
Hy,
i installed the SP1 for the 2010 version few hours ago.
But the compiler still have the same error message.
11-21-2013 01:16 PM
Did you install LabVIEW 2010SP1, and also corresponding FPGA module update (FPGA Module 2010SP1)? You will need to install both.
11-22-2013 01:45 AM
I just got the standart FPGA 2010 Version, will try the Service Pack for FPGA next week, when im back in office.
Anyway, I will give you an update.
11-22-2013 05:27 AM
Hy,
its me again, a new "problem" occured.
I cant find the download links for FPGA 2010 SP1 and Real Time 2010 SP1 on the NI page.
So can someone post that links here.
Thanks a lot!
11-22-2013 11:26 AM
Did you search for "FPGA 2010 SP1" and "Real-Time 2010 SP1"? The first links are the downloads:
11-23-2013 03:03 AM
Yes, i searched with that keywords.
If i click on your FPGA Link, i get a message from the ni site that there is no result that match to my keywords.
With the RT Link i get 3 results, but there is no 2010 SP1 as a result.
😕 Help 😉
11-23-2013 09:49 AM
Well, that's strange. It works for me. How about searching Google for:
site:ni.com "LabVIEW FPGA Module 2010 SP1"
site:ni.com "LabVIEW Real-Time Module 2010 SP1"
With those searches I get these links:
http://www.ni.com/download/labview-fpga-module-2010-sp1/3206/en/
http://www.ni.com/download/labview-real-time-module-2010-sp1/2382/en/
If those don't work, try another browser or configure your browser for English language (if it isn't already) and see if that makes a difference?
11-25-2013 08:28 AM - edited 11-25-2013 08:42 AM
Hy,
so here is the update.
On my system is now runnung labview 2010 SP1, FPGA 2010 SP1,Xilinx Compiler 11.5 & 10.1.
I'm still getting an error from my compiler.
(By the way, all kind of FPGA works fine with my compiler. Only the "Spartan 6 FPGA" doesn't work.)
Details:
ERROR:TclTasksC:process_077: Failed to complete. Please inspect the log and report files.false
while executing
"process run "Synthesize - XST""
(file "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\synthesize.tcl" line 20)
ERROR:HDLCompiler:806 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 64: Syntax error near ",".
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 72: <knumberofdmachannels> is not declared.
ERROR:HDLCompiler:854 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 29: Unit <pkgcommintconfiguration> ignored due to previous errors.
Parsing package body <PkgCommIntConfiguration>.
ERROR:HDLCompiler:688 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 135: Package declaration pkgcommintconfiguration is not yet compiled
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 137: <boolean> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 138: <natural> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 140: <knumberofdmachannels> is not declared.
ERROR:HDLCompiler:24 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 140: "**" expects 2 arguments
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 141: <maxwidth> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 143: <maxwidth> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 146: <boolean> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 147: <positive> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 150: <knumberofdmachannels> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 151: <maxdepth> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 154: <maxdepth> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 157: <natural> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 158: <natural> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 161: <knumberofdmachannels> is not declared.
ERROR:HDLCompiler:69 - "C:\NIFPGA\jobs\N2UzRd8_YTw6YCp\PkgCommIntConfiguration.vhd" Line 163: <numofchannelsused> is not declared.
Sorry, too many errors..
Total memory usage is 206896 kilobytes
Number of errors : 19 ( 0 filtered)
Number of warnings : 0 ( 0 filtered)
Number of infos : 0 ( 0 filtered)
Process "Synthesis" failed
Start Time: 14:58:42
End Time: 14:59:34
Total Time: 00:00:51,174
I did't have the Real Time Module, because i just want to use the FPGA on my CRIO-9076.
Is that maybe the reason for that error? Is it mandatory, if i only use the FPGA?
Or got anyone an idea what else can be the source of error?
Thanks a lot 🙂
